4 Bar MAP Sensor and wrong table scalers?!
Roman_CTR
Post by Roman_CTR »
I want to run a 4 Bar MAP Sensor with KPro.
I changed it in the parameters. In the options i checked "show 5 Bar Tables".
But in the Tables itself the table scalers are just showing up to 1.9 Bar.
When i click right on the last column, choose change Load index the small edit box shows its right value 2.92 Bar.
Is this a bug or can i change any parameter to display it right?
Thank you!
There are 16 load columns. Most calibrations have these mapped to 3 bar. If you are running more boost that that, then you will need to set the load index yourself.
What 4bar are you using?
Roman_CTR
Post by Roman_CTR »
Thank you for the quick answer.
I use the Hondata 4 Bar MAP.
I took a screen shot - please see the attachment.
The strage is, on the screen it's displays 1.9 Bar, but the Edit Load Index shows 2.92. Even when i confirm the editor box the table heading keeps unchanged.
Now, please tell me, in this example: Is the column 16 for 1.9 Bar or for 2.92 Bar?
You must go to Options and select show 5bar tables.
Roman_CTR
Post by Roman_CTR »
The screenshoot was taken with the "show 5bar tables" option allready selected!
Roman_CTR
Post by Roman_CTR »
I just tried it again. No luck again.
BTW. nothing changes when i try the options "show 3 Bar Tables" or "show 5 Bar Tables".
And nothing changes when i try different Map Sensors from the Quick select.
Is there any additional step when i select a different MAP Sensor?
No, you have it set to show 3bar tables. There are 24 columns when you have it set to show 5bar tables.
Roman_CTR
Post by Roman_CTR »
Spunkster wrote:No, you have it set to show 3bar tables. There are 24 columns when you have it set to show 5bar tables.
Really?
I'm sorry, thought this was Smanager not Kmanager.
I've just checked and as long as you have it set to show 5 bar you can go and edit the load index and i was able to set to 4 bar in column 16.
Make sure you go to Options, settings, Units and make sure you have your pressure unit base set to absolute.
Roman_CTR
Post by Roman_CTR »
Ahhh, hurray it works now.
The problem was the "pressure unit base" was not set to absolute.
Thank you!
