s300 problem
couperoop
s300 problem
Post by couperoop »
2 Questions. What would be some of the problems i might encounter using vista 64 bit.Iam using it now,everything works but encountering some prob,s .want to make sure its the software not the user. :
why would my datalog lock up only when i go 100% throttle in high rpm situations,low throttle no prob,s only when in high stress situation.
B18a1 ls vtec turbo,S300 93-Civic Coupe
Vista 64 works ok.
Datalog cutting out at high rpm is from ignition interference. Check you have resistor type spark plugs and use only stock ignition wire.
