boost
xander1100
boost
Post by xander1100 »
im buying a used s200 and i was looking at the options of it and under boost control it made it sound like i needed that for my turbo to work properly. i already have a greddy profec b spec II boost controller, do i need the upgrade from hondata still or will the "Expanded fuel & ignition tables for boost" feature that the s200 comes stock with work fine?
The s200 has fuel and ignition tables for boost, but it cannot control a boost controller to regulate the boost pressure, use boost by gear or RPM, and is not easily user programable. The s300 would be a much better choice for anyone planning to run boost.
xander1100
trying to not spend a lot of money, and i found a used s200 for about $200, thanks for input. i think the profec 2 connects directly to the turbo so it would work independently of the s300, am i correct or wouldnt it work?
