K20a3 & dataloging output
BrianZ
Post by BrianZ »
I noticed while using a K20a3 basemaps that under the multiplexer settings I cannot select "non-honda output" or either of the datalogger outputs. Is there a way I can select any of the dataloger outputs when using a k20a3 basmap?
in KManager, go to Help, Contents and search for "serial output"
BrianZ
Post by BrianZ »
I have already added the "DataloggingOutput=1" to my ini file. I’m not sure what ECU that is in the car but it came with the last motor, A JDM K20a (purchased as a complete swap). I was able to select and use the data-logger output with my tuned K20a file, but when I load a K20a3 map (one supplied with Kmanager) the option is grayed out.
The serial output is only supported with PRB based calibrations.
BrianZ
Post by BrianZ »
Thank you
