S300 newbie question
garrettrs
Post by garrettrs »
Hello,
Just installed my S300 on the Honda D16.
Everything is working fien so far car works connection to ECU works fine.
Now my question, what need to be activated that you see where u are right now (rpm, ignition, etc.) so that you see where exactly you are in the map ind different conditions? Real-Time Display????
Many thanks
FreshDA9
Post by FreshDA9 »
the lightning bolt starts and stops datalogging and the red record button start and stops recording of that run and you can then save it to a file to reference later.
Also if you open your software goto help then contents it will explain alot more of the software just to let you know.
You can also use F10 to datalog and F9 to record.
