S2000 imobilizer
benlen
S2000 imobilizer
Post by benlen »
Can the K-pro ecu be spliced into existing ecu so that i can keep my imobilizer. It seems that every single ecu upgrade on the market would require me to lose the imoblizer. This is a big no no for me. Its is stopping me from tuning my car any further.
The S2000 and K-Series immobilizers are different and cannot be used together.
What year is the s2000?
benlen
s2000 immobilizer
Post by benlen »
2004 AP2
benlen
s2000 immobilizer
Post by benlen »
What is the problem with the s2000 ecu? Is it read only or will Honda not share the software to reprogram it.
00-05 S2000s use a non-programmable ECU that not even Honda can reprogram. THe chip is a write once, like OBD2A andOBD2B Civis and Integras. THeimmobilizer system on an 00-05 is also not the same as an 06-09 S2000 therefor it is not compatible witht he RSX immmobilizer used in the K-Pro.
Only an 00-09 S200 can retain the immobilizer funtions with K-Pro.
benlen
s2000 immobilizer
Post by benlen »
If i split the loom and keep everything necessary to start the car in one loom and plug it in existing ecu and use an output off it to power the k-pro. Then i could use the other part of the loom with tps,injecters etc to plug into the k-pro and it could run the car. Piggy back it so to speak. The old ecu would be used just to start the car (sort of a glorified alarm) and the k-pro as the brain. Its a bit of extra work but it is easier than trying to find a robbed car.
No, that will not work
