help!!!! b20 vtec setup using P28 ecu someone help!!
nrsoul
Post by nrsoul »
i got a b20 vtech setup i am confuse, i am using a p28 ecu. am i losing power? should i get a p72? its a obd1 motor.....
FreshDA9
Post by FreshDA9 »
you should get it tuned asap no ecu has the correct maping for that setup.
nrsoul
Post by nrsoul »
FreshDA9 wrote:you should get it tuned asap no ecu has the correct maping for that setup.
what should i get??
To use a Hondata system, you will need to use a compatible OBD1 ecu from the list at http://www.hondata.com/ecus.html . You can then use the Hondata s100 or s300 depending on what options you want ( http://www.hondata.com/sproducts.html ). I would recommend the s300.
