Is this Normal??
Javcolin
Is this Normal??
Post by Javcolin »
Hello,
Finally i found the problem with The LC-1. So i was checking the values from Smanager wideband and the Logworks and both match nicely.
So i loaded P30 stock map and started to datalog. my car is a B16A2
what i noticed is that at idle Both Smanager AF Display and logworks shows lets say 14-15 AF but on the fuel tables it shows 12.34 AF.
Is this Normal???
or is there something wrong here??
i thought that the fuel tables readings were the actual wideband readings.
Now i'm a bit confused since i have most of the cells at 14. something but they can be wrong any one has experience this before??
How do the fuel tables indicate 12.34? Do you mean target lambda?
Javcolin
Post by Javcolin »
Sorry about that. i ment to say.
looking at the tables with overlay lambda on the dattalog botton.
its showing under idle cell around 800 rpms 12.34 but my display on both smanager and logworks 14-15 AF. is this normal?
i thought that it would show the actual reading from wideband doesn't it??
Thanks for the help.
Javcolin
Post by Javcolin »
I loaded P30 basemap, and i'm using Logworks and Smanager Display to see if there is any difference in AF between each other. and they both match. so i test drove my car and monitor the table using the start dattaloging botton. So my low fuel map table is filling out with the overlay lambda. showing different AF reads most of them not so bad.
but at idle it shows 12.34 while my Display on Smanager Shows 14. something to 15 AF. why is this differece between each other???
Is there any way to make the diplay AF ratio to read a bit slower?? since mine reads so fast that oscilates quiet fast to see the actual reading, while AF display on Logworks reads more stable. i guess reading update is a bit slower.
What is the AF reading in the display window in Smanager or in the Sensor list?
Javcolin
Post by Javcolin »
Hello Spunkster,
My reading on the display window or sensor window is 14-15 AF while on the fuel tables when i select the overlay lambda under dattalog or recorded AF table. around 800 rpm is 12.34
now with this difference i'm not sure if he rest of the fuel table shows the correct AF.
What are your overlay settings? By default it will not overlay lambda with the throttle closed.
If you want to avoid the guessing game as to what is wrong then you need to follow the posting guidelines.
