Raise in Idle When Datalogging
dylans
Post by dylans »
I have wired in a switch for the on-board datalogging, The switch goes into the B5 Air Conditioning Switch on the ECU. The on-board datalogging works great, my only problem with it is that everytime i flip the switch to on to start datalogging, it raises the idle from around 850rpms to about 1050rpms. Is this due to it being connected to the A/C port and his the ECU raises the engine RPM when it is activated, it does the same thing for the datalogging? Is there anyway that I can get rid of it so that my engine idle doesn't increase when i use the switch to activate the datalogging? Car details are below and I attached a datalog where i didn't have the switch activated and then I activate it so you can see the raise in idle. Thank you.
-Dylan Smith
Car:
1996 Honda Civic DX
B18B Engine
Yes, it is because the AC switch is increasing the idle speed. I've fixed this for the next release.
dylans
Post by dylans »
Great! Thank you...any idea on eta for the release of the new version?
darknight
Post by darknight »
I have run into this issue as well and the only way to solve it is to use an alternate pin. I have always either used the service indicator pin or the power steering pin.
