Tune or ECU??
hatchgs
Tune or ECU??
Post by hatchgs »
I have S200. I bought a wideband. I had my tuner adjust my old fuel map to better suit my cams i hated running 12:1 AFR @ idle and 10.5 @ WOT
The car was running fine before no cel. Rewrote the chip and now we are in limp mode. We tried many differant tunes. We tried the ecu in a differant car. Also 3 differant chips.
There is a solid red light on the blue box. Thoughts input. What could have happened to the ecu?
When you datalog, what error codes are you getting?
hatchgs
Post by hatchgs »
okay we didn't datalog anything.
we tested the rom it is good
blue box is good and the wiring is good
the ecu is bad.
what is the next thing to do?
Well if you know it's the ecu then it's either a soldering issue or you need a new ecu.
hatchgs
Post by hatchgs »
could this be the culpret
That picture is too blurry to make out anything. What are you referring to?
hatchgs
Post by hatchgs »
i saw a white stuff like a strach. right below that screw but i check for continuity and i heard a little beep.
i heard if i cut j1 the ecu would go back to stock. is that true? i don't believe it because that is a reason for limp mode
God's telling me to go for S300
Yes cutting J1 will allow the ecu to go back to stock.
