is there a way to make a sound for shifting
spider00rr
Post by spider00rr »
how do I make it beep or play a sound when I am about to hit redline. I have heard of people doing this but I have never seen it.
geoffrey70
Post by geoffrey70 »
This one works perfect, adjustable three beeps, set at whichever rpms you prefer. Its super loud too.
http://www.modifry.com/products/rlb/index.htm
spider00rr
yeah that is cool but I have heard of people doing it with the kmanager in the display part. since I have a carputer it would just play over my speakers
In the display window set the warning rpm to your shift rpm, select a warning sound and set 'warning sound on change' to false.
carbonctr
Post by carbonctr »
spider00rr wrote:yeah that is cool but I have heard of people doing it with the kmanager in the display part. since I have a carputer it would just play over my speakers
As Hondata says to do should work. Unfortunately my CarPC has an issue with this in KManager and only beeps once when I hit 8000rpm then never again until I restart the PC. I think it is a audio driver issue as I had it working fine once but it stopped working again after a KManager update. Now I've given up and just keep one eye in the rev counter - in PC display of course :-)
It is odd because if I set any other gauge to do the same, like TPS, it works fine. Only the RPM gauge that I want to work will not :-(
Please let us know how it goes...it is possibly an issue with some CarPC's. I have a Jetway J7F2 motherboard with latest BIOS, latest audio driver etc.
A CarPC is a great idea for KManager. I like to watch the tables moving around while driving - looks the part!
spider00rr
yeah I still could not get it to work. I have a warningMin and a warningMax but I don't know what to set them at I put the min a 8500 and the max at 8600, set the sound and left the sound on change set to false but I only got a sound when I clicked close. other than that it would not work
spider00rr
still can't get it to work am I doing something wrong ?
set the min to 0 and the max to 8500
carbonctr
Post by carbonctr »
Try adding a TPS guage to your display and set its WarningMin to -10000 and WarningMax to 30. Now you can switch on the ignition without starting the engine and see if the warning sound works when you push the throttle over 30%. I did this to test mine. The TPS guage beeped fine but the RPM one wouldn't work correctly. At least this will let you see how to set it correctly to make it sound.
carbonctr
Post by carbonctr »
spider00rr wrote:still can't get it to work am I doing something wrong ?
Have you managed to get it working yet?
