PNF ecu from my SiR (AKA si), running a z1?
nicotine
Post by nicotine »
so...
quick low down:
i got kpro done to my PNF ecu - which originally was for my EP3 SiR (canadian :D)
im swapping out the engine for the type-s 05 z1 block, but using the tranny from a 04 (which i have on my a3 block now, works great, no vss issue)
will there be any problems with wiring/sensors using the z1 block with my pnf ecu that has been kpro'd?
thanks!
The only problem will be that if you have a 6 speed transmission, you will not have reverse lockout.
nicotine
Post by nicotine »
yeah, i already don't...i have a type-s tranny on my a3 already....
and R is sooooo far over to the right, compared to 6th.. I don't know how anyone could screw that up ! :P
thx for the help!
