wideband in place of o2 sensor
KING
Post by KING »
I have a 94 civic dx, built gsr sc61 and s300. Im wondering if there is any reason not to use my wideband in place of the factory o2 as in NO factory o2 I just wire the wideband in to send signal to ecu.
jdmspecdc5
Post by jdmspecdc5 »
thats exactly what i did. just make sure you wideband has a narrowband output for the ecu so it will run correctly in closed loop.
KING
Post by KING »
jdmspecdc5 wrote:thats exactly what i did. just make sure you wideband has a narrowband output for the ecu so it will run correctly in closed loop.
I have the lc-1 wide band and it has the output. have u had any problems running it this way?
hybridcivicls-t
Post by hybridcivicls-t »
I have the AFX NGK wideband. I was going to do that but the wideband placement is a little further than i want. so i opt to keep the stock one in and use the wideband
you wont have any problems with it though
98h22
Post by 98h22 »
will the car run correctly in closed loop without a o2 sensor or wideband hooked up to s300?
No you cannot run in closed loop without a narrowband signal or a simulated narrowband signal.
98h22
Post by 98h22 »
is it safe to always be in open loop until i get my new o2 sensor?
That all depends on the tuning.
