SManager V1.4.1
SManager V1.4.1
V1.4.1 (11 March 2009)
• Moved application files to user's local data directory to stop Vista Virtualization
• Added datalog and error code prompts.
• Added option to disable the screen saver when datalogging.
• Added ignition retard to strain gauge based full throttle shift.
• Added the option to force the radiator fan on at a temperature.
• Added maximum speed to nitrous conditions.
• Fixed AC switch increasing idle speed when AC switch used for other purposes.
Unfortunately we have had to move some of the file locations around to keep Vista happy. More information on file virtualization can be found in the help file
FreshDA9
Post by FreshDA9 »
Thank you for the radiator fan control and im hoping to use the strain gauge here in the future. on another thread in here i herd someone talking about a speed limiter option i think this would be a great feature to add.
Silverbeast
Post by Silverbeast »
Thank you... Vista with UAC turned on was a PITA to tune with.
DOHCAccord
Post by DOHCAccord »
Thank you.
V-Spec race development
Post by V-Spec race development »
thank you sir.
turbotypeR
Post by turbotypeR »
thank you thank you thank you! for the strain gauge feature!
sorry i kept buggin you about it.
hondata rules!
92 civic Si
best et:9.43best mph:164
turbotypeR
I did have one question though. I assume the retard is not like on/off? Does it come back on full blast, or gradually? If it comes back in full blast it will still hit hard.
92 civic Si
It is a timed retard, then a return to full ignition timing. If you want it to ramp back to full timing, can you provide details of the retard duration, amount and rate of change?
turbotypeR
I was just thinking that it could have the same adjustments as it does now, retard and duration of the retard, and then add a duration of the ramp to full timing. Then the timing could ramp back in based on time. The longer the duration, the longer the ramp back to full timing. Does that make sense, or seem like something doable?
92 civic Si
Seems reasonable. I'll add it to the list.
RedR
Post by RedR »
can´t get the fan to work based on the coolant temperature i want it to start....am i missing something?
Is the fanc output wired to the fan relay?
turbotypeR
Hondata wrote:Seems reasonable. I'll add it to the list.
I can't explain how much you guys rule!
92 civic Si
RedR
Post by RedR »
nah i havent wired it, but i assumed this would work like in the k-pro and it doesnt require any wiring
Depending on the car it may require additional wiring.
