How do I Connect a Toggle Switch To The Clutch Switch.
Turboracer01
Ok So Obviously we have the 2 step option as part of the hondata Stage4b and with the clutch pedal pushed in the two step is activated and I can't rev past a certain rpm. The problem is that When I need to do Burn out I need to rev high like around 7-8 but obviously to do a burn out I need to push in the clutch at first, rev and dump. But with the 2 step set at 5 I can't go any higher. So I was told I could put a toggle switch on the wires connected to it, so I thought I figured out the - wire and the + wire (or so I thought) I was using a test light to make sure which one was which and the Negative turned on the light and than I went to test the other wire which I assumed was the positive but got no light on with my test light. So I'm assuming If I hooked up a switch to it wouldn't work. Unless you guys have any other ideas or something I didn't try. Any help wold be great! Thank You
Try wiring the toggle switch in parallel with the clutch switch, putting it between the clutch switch and the interface box. This way with the switch open, the current must travel through the clutch switch, but with the toggle switch closed, you short the circuit and therefore take the clutch switch out of the equation.
Turboracer01
Yea I was trying to install the toggle switch between the clutch switch and the hondata box. But the Problem I was having was that when I was testing the 2 wires going to the Clutch Switch I found the negative and assumed the other wire was the power(positive) wire but when I tested it My test Light wasn't going off So I'm assuming I wasn't getting any current Cause the light didn't turn on.
