Enable Lean Protections
hybridcivicls-t
Post by hybridcivicls-t »
I have read the help topics and understand what it's asking but im not sure exactly.
My leanest at cruising is in the neighborhood of 16.5 on E85
in boost it's around 11.5ish
Im not sure what would be the correct trigger times.
thanks
Martian
Post by Martian »
Lean 1
Max Lambda:14:1
load: 4psi
triger: 250ms
lean 2
Max Lambda :13:1L
Load: 15psi
Trigger: 100ms
That a good place to start, and can be adjusted if needed.
thank you, thank you, I'm here all week
hybridcivicls-t
Is this setting at WOT?
is the "ms" milli seconds?
and my max boost is 20
You control when it is activated via the settings and yes the ms means miliseconds.
hybridcivicls-t
ahh ok i get it.
the first lean protection is a fail safe for a lower going into boost and the 2nd is for already into boost and lean conditions take place.
Am I correct?
