Hondata help needed please...
Crxmanror
Post by Crxmanror »
Recently i have been doing some datalogs and on all of them i have found that my car runs in column 7 under WOT. All the information that i have found states that in WOT a NA car should be running in columns 8 and above. One thing that might be causing this is the altitude that i am at, i have not found anything that would say altitude could cause this. Has anyone else experienced this type of problem. Any help or things that i can try to correct this would be great. I also included my datalogs and calibration to show what i am talking about.
What is your elevation?
Also if you enable the OBD2 functions in the ecu and do a quick datalog, you will be able to see what the atmospheric pressure (PA) is and you should be able to come very close to that reading at WOT. If you do not, then you have a restirction.
Crxmanror
Post by Crxmanror »
Ok i'll try what you mentioned and see if that works. The altitude that i am at is 6000+ feet.
Crxmanror
Post by Crxmanror »
Atmospheric pressure according to the ECU is 82 kpa.
Your WOT is the same as your atmospheric, so that is normal.
Crxmanror
Post by Crxmanror »
Spunkster wrote:Your WOT is the same as your atmospheric, so that is normal.
Thanks spunkster... Kinda thought altitude played into where the car runs in the maps.
