Cruise control in TSX
valeratj
Post by valeratj »
Hey, I read that if I was to get k-pro for my tsx, I would lose cruise control function and that kind of holds me back at the moment. I got 2 questions regarding this;
1- Are there any plans to fix this downside later?
2- It says that a stock ECU can be plugged back in with rev limiter set at 6000 rpms and no VTEC. So, would cruise control work in that scenario?
Thanks !
No, there are no plans for the future that would allow the cruise control to function properly. No, cruise control will still not work if you disconnect the K-Pro ECU.
The cruise control is disabled with the reflash to the stock ECU as using the cruise control once you have K-Pro could become a saftey issue.
valeratj
Post by valeratj »
awwww thats sad, but ok. Thanks !
locash
Post by locash »
You could always buy another stock ecu with the key and transponder, and use it for long trips.. :)
Locash Racing, LLC
Hondata Sales and Tuning
Dynapack 4000 2wd Dyno
In-Shop CNC Machining and Product Manufacturing
