boost level
98h22
boost level
Post by 98h22 »
my car is currently at 20psi and was street tuned,in order to turn the boost up a couple pounds will i need a retune or just pay attention to wideband and see if the a/f ratio's are ok?
V-Spec race development
Post by V-Spec race development »
it should be fine as long as the fuel map up to 3 bar is look good then just make sure your a/f is good.
cardinal811
Post by cardinal811 »
NOT SAFE
depends on what your ignition advance is,
If your going to give advise back it up with some experience that you know.
Dont believe everything you read on the internet kids
It must be tuned on the dyno in order to run safely.
