Hesitation/Fuel Cut on light throttle with ITB Setup!?
doc
Post by doc »
I have problem on a Lotus Elise with K2x+ITBs. It's a race car. KPro is configured to Alpha-N. Car is tuned so far, no problems (back with 1.3.4 after the terrible buggy 1.3.5.x versions)
The only problem i run into with KPro is, on very light throttle, in gear (car is rolling) it runs into the fuel cut. This happens some times up to 3000rpm!? It's just annoying when rolling on the trailer or through the pitlane :(
TPS is calibrated. IACV is enabled, and connected.
And, and when you add some features, TPS-Tipin would helpful on ITB's and some NA builds, too.
It would be good to have more control over the fuel cut parameters. Like total disable, min TPS, RPM cut/resume ...
Doc
PS: sorry, no calibrations and datalogs, it's a customers car.
cranny
Post by cranny »
fuel cut is on the redline. your describing what sounds like lean cut/protection.
why dont you run a MAP sensor?
sinistrs2k
Post by sinistrs2k »
I'm seeing something very similar, would like to know more about this as well.
Thanks,
J
KPro Serial# 5071
02 S2000
I/H/E
Without calibrations and datalogs showing the problem, it is impossible to know what the problem may be.
