dataloging AF cuts out at high rpm
SOHC_STUDENT
Post by SOHC_STUDENT »
After about 6000RPM datalogging of AF cuts out. Hondata continues to datalog everything else except AF.
I've got an Innovate LC1 connected to D10 ELD.
megomaniac
Post by megomaniac »
are you using resistor type spark plugs?
H22A4
turbo
S300
SOHC_STUDENT
megomaniac wrote:are you using resistor type spark plugs?
yes, ive tried both NGK BKR6E11 and ZFR6FGP
inteGReddy
Re: dataloging AF cuts out at high rpm
Post by inteGReddy »
SOHC_STUDENT wrote:After about 6000RPM datalogging of AF cuts out. Hondata continues to datalog everything else except AF.
have you verified that it is correcting datalogging before 6000rpm?
im stumped on this one so far and have to think its either a wiring or parameter issue.
You'll need to go over all the wiring you have done as it sounds like something is loose.
