TSX K-Pro Questions
Tsx536
TSX K-Pro Questions
Post by Tsx536 »
I'm looking to get K-Pro soon and have a few questions:
1) On the TSX K-Pro page, is says to use a D17 Civic O2 sensor. Can a 02-04 RSX O2 sensor be used instead? Why was the Civic O2 sensor chosen vs. the Civic O2 sensor?
2) On the TSX K-Pro page is also suggests to use a VTC from an RSX/Civic Si. This allows up to 50 degrees of CAM advance. I've seen other info that suggests it is safer to Machine your existing VTC to allow up to 45 degrees just in case your mis-shift or over-rev.
I have an Automatic tranny though, is this not an issue for me?
3) I currently have a Comptech SC with Stock Injectors and a crushed FPR. Do I need to swap back to a regular (un-crushed FPR) if I want to run K-Pro or hi-flow injectors?
Thank you for all of the help,
Kenny
You cannot use the RSX sensor as it is the wrong sex and not long enough.
I'll have Doug answer your other questions.
Hondata1
Re: TSX K-Pro Questions
Post by Hondata1 »
Keep your crushed FPR. A little extra fuel pressure helps in a force inducted vehicle, and you tune for exactly the fuel pressure you have.
I've changed my mind on the VTC mechanism and changed the web page to read 45 degrees max. Reason is is that we have lost the measurements we took when we disassembled the TSX engine several years ago to measure valve to valve and valve to piston clearance. We know 45 degrees works perfectly as I have been using it daily for several years.
Leave modifying the VTC mechanism until I have determined the cam angles a supercharged TSX needs. That will be this week.
Garrett_si
Post by Garrett_si »
Does the D17 02 sensor is a wideband like RSX 02-04 one?
yes, from the website:
- Air Fuel ratio sensor from a US 2004-2005 D17 Civic (Part # 36531-PLR-003)
rex.
Post by rex. »
I cross referenced the Civic O2 sensor 36531-PLR-003 and found the DENSO 234-9017 is equivalent. I'm curious to whether or not this may be an alternative to purchasing the OEM from Honda
I do not know. We find it best to ues the OEM parts.
rex.
Post by rex. »
Thanks, only reason I mention it because it should be about $70 cheaper.
Does the Civic sensor need any modification to work with the TSX?
no it plugs right in
rex.
Post by rex. »
That's great to know
Any .kal's included that will be TSX specific?
ie; Kind of like the reflash tune as a base tune
Thanks for answering my questions btw
Tsx536
Post by Tsx536 »
Nice to see you over here too Rex!
There's already a TSX Base cal out there. It was created/tuned by LoCash on his dyno.
Here's the thread on it:
http://www.hondata.com/forum/viewtopic.php?t=9058
rex.
Post by rex. »
I see, so his tune is included..
I wonder how it will work with a 2006
I'm trying to decide to whether to save for the supercharger or get the kpro first
Luke
Post by Luke »
i propose to get the K-Pro first or both at once.
with the k-pro and the new cal you will have some more fun with your car.
after the SC installation you'll surely need the K-Pro to tune it properly.
in my opinion there are 2 sollutions:
a) buy the K-Pro now and use it
b) save as much money to buy both things at once. this will allow you to tune your car properly and receive the highest power output.
best regards Luke
Malkolm666
Post by Malkolm666 »
is there any issues to use a differnet MAPsensor with the tsx Kpro? I want to use a 3bar mapsensor.
I read on you website:
"As there is no communication between the stock ECU and K-Pro, the status of the cruise control and air-conditioning, under control of the stock ECU, is not conveyed to the K-Pro."
Does that mean that AC is not working?
Yes, you can use a different map sensor. It is highly recommended to use the Hondata 4bar map sensor since it a direct plug and play piece and requires no wiring and fits in the factory location.
