datalog stops on dyno pulls
EGHATCH
Post by EGHATCH »
street tunine at part throttle works with datalog, idle, etc. it never stops
but when i went to dyno earlier, at WOT, datalogging just stopps.
i have to discounnect and reconnect the cable and f10 again...
bkre9ix.
stock ign system
you wont learn until you actually do it.
It may have non-OEM plug wires or cap and that may be causing the problem.
crucian
Post by crucian »
Why do we have to use OEM plug wires and Cap for a product we paid for to tune our cars?
Because they may produce large amounts of interference. This is not something we can control or change on our end. The OEM parts are made to very high spedifications and must meet certain criteria. Aftermarket ignition components do no have to meet these strict criteria and are known to cause problems. We have seen cars make over 900 hp with the stock ignition system.
crucian
Re: datalog stops on dyno pulls
Post by crucian »
EGHATCH wrote:street tunine at part throttle works with datalog, idle, etc. it never stops
bkre9ix.
stock ign system
Also try a different USB port on your laptop if you haven't already done so.
