780 cc injectors fuel map looks wrong
mooserov
Post by mooserov »
I'll post the cal later, but to get the car to idle with a decent afr, my map has a big dip in the cells where it idles. I've started over a few times, but I cannot keep the lines on the 2d maps from crossing. I've read here that the fuel maps will not look 'normal' with bigger injectors.
What is the richest idle I can have without being concerned? I'm idling around 10.5 to 11.0
Are these low impedence or high impedence injectors? Are you using a resistor box?
