2003 honda civic ep3 type r jdm spec
mivec24
Post by mivec24 »
Good day all. Well i am new to both honda and hondata. I bought my type r a month ago came with greddy turbo kit and emanage but i wasn;t happen with turbo kit or emanage so now i am upgrading.
I bought a hondata system that works with 6 speed and they said its a PRB ECU for the RSX type s. Now i didn;t know about all these different codes like PRA whats not but i hooked it up on my car. My car will not start and i observe that i am not seeing any crank sensor or cam sensor signal. Also the speed sensor stays at 48. Is there a way that i can get this ecu to work on my car.What would i need to change to make this system work right now i have stock ecu controlling 440cc injectors and thats not good. Any diagrams you can send me would be help full as well. My car was bought from Japan.
What is the ECU code from the stock ECU in the car?
fonz600
Post by fonz600 »
Have you uploaded a map to the ECU? If so which one?
