05-06 Kpro tranny problem
h2nrtl
Post by h2nrtl »
we have a 06 RSX that we put Kpro on a while back. The transmission was broken from 2nd gear letting go. We got a 07 SI tranny and swapped it in because it was cheap and had LSD. Now the speedo is going crazy and when we log with Kpro the speed goes to 140mph by the time you are at 20-30mph. Is the counter different in the 07 Si than the 06 RSX that was in there? Or are the speed sensors different and need to be swapped?
Also if turn off the speed sensor and provide a constant signal will the Vtec and VTC still work until we can get this fixed?
Post your calibration and a datalog showing the problem.
