Secondary Table question
b20luda
Post by b20luda »
OK, If im already using a dohc vtec motor can i still use secondary tables or is this pretty much for non vtec only? Is there somthing im missing...
Im putting methanol on the car, and using my normal Map (high speed) for a safeguard basicly anything above 18psi with have a heavy ignition retard, anything below that boost level it will have a normal tune on it, i want to switch to another map via pressure switch (inline with the methanol) so once it sees pressure it will switch to the map thats tuned properly for it?
Secondary tables can be used by anyone for whatever purpose they choose.
b20luda
Post by b20luda »
where the tables at then?
b20luda
Post by b20luda »
OK im a retard... i didnt notice that when you clicked the secondary table box in the tables window it switched tables, its hard to tell!!
