Rotrex Supercharger map
luke_sedz
Post by luke_sedz »
Hi,
I am new to the world of Kpro.
I have a Rotrex supercharger with a kpro and a map installed on it for the setup as it was in the old car:
EDM Honda Civic Type R with a stage 2 rotrex supercharger and a top mount intercooler.
I have now changed this setup into a different civic but put a front mount intercooler on it, the cooler is about the same size but the pipe work is a lot longer and its obviously getting more cold air.
Can I run the map safely from the previous setup and would it be easy to modify this if needs be?
Thanks a lot
Luke
You will have to use a wideband to see if it is safe. You have a fully tunable system, it can be tuned by yourself or a tuner for whatever modifications you do.
