Problem with datalogging
ROM Editor 4 tuning software questions and answers.
bonso
Post by bonso »
Hi, I got my RE4 and bought a used s200 to replace my old faulty one. when start tuning the highlighted area on colums(fuel/ign map) doesnt work while the car running. do i have problem with datalogging even though i have unlocked the codes for datalogging on the used s200?
thanks
Have you clicked the datalog button?
bonso
Post by bonso »
Spunkster wrote:Have you clicked the datalog button?
Yes, but its not working. the highlighted colum should move right and down according to the engines behavior right? everything works except for datalogging...
ITR 1102
Post by ITR 1102 »
Is J12 cut on the ecu?
solid or flashing red LED on the s200 interface box?
bonso
Post by bonso »
ITR 1102 wrote:Is J12 cut on the ecu?
J4 is cut and solid Led with the s200 on my p72 ecu. my p27 wont communicate with the s200 the red led is flashing. but hopefully have the datalogging working on the p72 for now..
HAve you actually burned a chip yet? IF the light is flashign then there is no communication between the chip and the s200, so you have either a blank chip, bad bin file in the chip, or a bad ecu socketing job.
bonso
Post by bonso »
Spunkster wrote:HAve you actually burned a chip yet? IF the light is flashign then there is no communication between the chip and the s200, so you have either a blank chip, bad bin file in the chip, or a bad ecu socketing job.
Hi, the light is flashing with my p27 ecu but not in my p72. yes i did burn a chip with the p72 for a test, it is responding except for datalogging.
Please see page 12 in the s100/s200 user guide: http://www.hondata.com/downloads/S200%2 ... 0Guide.doc
bonso
Post by bonso »
Spunkster wrote:Please see page 12 in the s100/s200 user guide: http://www.hondata.com/downloads/S200%2 ... 0Guide.doc
My main problem is not having the datalogging to work on my p72. i dont have this problem with the romeditor3 before. but since i upgraded to RE4 and using a replacement s200 i bought from a friend (working fine) i suddenly had problems.. the highlighted colums on the fuel and ign map does'nt work. its really hard to tune without it..
V-Spec race development
Post by V-Spec race development »
You may have a faulty RE4 cable or a bad S200.
