Wall at 3000rpm
Mike B
Wall at 3000rpm
Post by Mike B »
I have:
1) K24a1/K20a2
2) RBC manifold / RDX 410 injectors
3) Brian Crower Stage 2 cams
4) Basic Boltons
5) Hybrid Racing Race harness. - this is the only harness in my race car
In idle. out of gear, I can rev past 3000rpm. My knock count seems to not exist.
Idle AF ratios are 20+.
When I engage the car in gear, I cannot drive past 3000rpm, it sputters, AF ratios are above 20+. The engine was purchased from a local but the tune was sent to me by the tuner. Everything is the same except the injectors which I have changed to 410, from 270. General Fuel trim is 35 and startup fuel trim is 20. Changing either doesnt make a difference.
However, my KPRO manager states that 02 Voltage is 0.00 at ALL times. I have never seen that number move. I imagine that is a bad 02 sensor?
Whats the problem?
EDIT: I am not getting any error codes either.
You need to take this to a tuner to be properly tuned before you damage the engine.
Mike B
Post by Mike B »
I appreciate the advice. I havent driven it for this sole reason. I am replacing the 02 sensor in the mean time because the last thing I want to do is get there, to find out a part is bad. The car needs to be 100% before it gets in the hands of the tuner, T1.
Spunkster, anything else other than the tune? If so, Im replacing it, Im not trying to skimp by.
Follow the posting guidelines. http://www.hondata.com/forum/viewtopic.php?t=3629
I think you have multiple problems.
