FlashPro annoucement
We will try to answer any additional questions on the product page or in this forum.
See http://www.hondata.com/flashpro.html
ImAuthenticFTW
Post by ImAuthenticFTW »
i have just three question initially,
1) Will this support a 64-Bit windows vista *fingers crossed*
2) are you guys going to release the software early to allow us time to search around and get used to it?
3) preorders??
1) Not at first. We need to make sure the USB driver is working 100% before handing over the money to Microsoft, because after that every change to the USB driver incurrs a substantial cost to re-certify.
2) Probably, but it is going to be very close to the release date.
3) Up to the dealer.
ImAuthenticFTW
damn no 64-bit, oh well just gotta go get a small laptop that will be used strictly for car tuning/datalogging then
anyone have any sugestions as to what would be good for that?
You can always boot the laptop into 'use unsigned drivers' mode.
k20z3+juice
yaaay for SI
Post by k20z3+juice »
first of all thank you hondata !!
can it control nitrous? custom launch setup, 2step ?, if i were to get my motor bored out , more aggressive cams ? can this now be tuned ?
The ECU is tunable for intakes, exhausts, headers, cams, bigger injectors, K24 engines, turbo chargers and superchargers.
Nitrous - not at the moment. Launch - yes. For other features see the page under 'Civic Si/CRT features'.
Karim
Post by Karim »
First thank you guys for the Flashpro
I have a couple of questions for you guys
I have an 08 Si and also purchased a K20z3 that is beeing fully built by Endyn and the corresponding ECU and gauge cluster. My question to you is as i make the swap can i use the current ECU or do i have to use the donner ECU and will i have problems with the immobilizer? I know it's a bit ahead of time to talk about this but i am curious none the less.
ImAuthenticFTW
Hondata wrote:You can always boot the laptop into 'use unsigned drivers' mode.
and doing this will allow my 64-bit laptop to run the drivers needed?? that would be awsome, how exactly is this done lol
dcloo
Post by dcloo »
some question
does the software work under win xp
the flash pro work on auto transmission
can it be tune more then 1 ecu/car
Karim wrote:First thank you guys for the Flashpro
Don't understand. If you have a 08 Si and are using a K20Z3 engine, what has been swapped? Why does the ECU need to be changed?
Press F8 when booting and select 'disable driver certification enforcement'. I believe that you can set an option to do this automatically every boot. Do a search for DDISABLE_INTEGRITY_CHECKS.
dcloo wrote:some question
Yes. No. Only 1 ECU at a time.
ImAuthenticFTW
yea man im not even gettin your build, your swapping in a K20Z3, but you do know that is what comes in the car right?? so it should use the same ECU anyway
chris2000
Post by chris2000 »
1. So does that mean 1 unit Hondata flashpro can only work with one ecu or car only? Which mean i can't buy one set flashpro and used it together with a few of my buddies civics?
2. Does it have control over DBW?
3. Any option of immobilizer control?
4. 90 sec programming - does that mean it can't do real time tuning?
5. If the ECU had been reflashed by another maker, can Flashpro still work?
Thanks.
