Questions regarding Kraftwerks dual kpro cal
eternallx
Post by eternallx »
I just looked over the cal for the KW kit and I see that the rev limit is set to 8500rpms. I thought the rev limit was lowered recently to 8200rpms? Is it safe to take my car pass 8200rpms?
Also the cal is running in open loop... should I leave it like that or change it to closed loop?
Hondata1
Re: Questions regarding Kraftwerks dual kpro cal
Post by Hondata1 »
Change it to closed loop when you have the correct sensor installed.
The lower rev limit you referred to was for the reflash not the K-Pro. Feel free to drop the rev limit to 8200-8300. It will keep the Rotrex superchargers within their rated RPM range.
That is completely up to you. It is a fully tunable system.
