NEED HELP WITH MY TPS!!! reading high voltage
boosted crx-r
Post by boosted crx-r »
my TPS reads 2% open when i am idling without pressing the gas pedal and 113% at wide open throttle followed by CEL for TPS high voltage. What is going on here? How do I fix it??
shut up and boost it!
Garrett_si
Post by Garrett_si »
calibrate it
boosted crx-r
found where to calibrate it and everything is working good now. thanks
savageevo
Post by savageevo »
i am having the same problem, where and how do you exaxtly calibrate it thanks all
Load your calibration into Kmanager, then with ignition on (engine not running) and datalogging, go to the Knock/TPS tab in Parameters and click read (minimum) with the throttle fully closed, then go wide open throttle and click read (maximum) a then upload the calibration.
savageevo
Post by savageevo »
thanks spunker, just did it and it works
