Question about purchasing FlashPro
COMplex
Post by COMplex »
Hello Hondata,
I currently have an 06 Civic Si with CT Supercharger and Stage 1 reflash.
I have pre-ordered the Stage 2 reflash, and plan to use a 3.0" pulley (at high altitude)
I am wondering, if it is possible to order FlashPro AND the Stage 2 reflash. together for a discount... Basically I want to be able to fine tune the Stage 2 reflash for use at my altitude with an even smaller pulley.
Is this possible to do all at once for a discount or do I have to purchase each separately for full price?
Or,
Can/Does the FlashPro already come with the Stage 2 calibration?
Thank you!
[COMplex] »»» civic.plex.nu
» Comptech Supercharged 2006 Honda Civic Si
» Information | Teaser Video
You will need to contact whoever took your deposit for the stage 2 kit and discuss upgrade options.
FlashPro has the CT stage 2 calibration.
COMplex
Post by COMplex »
Hondata wrote:You will need to contact whoever took your deposit for the stage 2 kit and discuss upgrade options.
Excellent. You answered my question perfectly. This should work exactly as I need/anticipate.
EFhatch
Post by EFhatch »
Does CT calibrations will work with FN2 Type-R EDM car if it's installed CT supercharger in the car?.
EFhatch
Post by EFhatch »
none reply? i was looking for get one CT superchargar and install into FN2 car. let me know plz!
I do not believe that there is a reflash or calibration for the Euro CTR.
EFhatch
Post by EFhatch »
Does will work ok Civic SI?
really what are difference between both maps ? i means SI map vs FN2 map?
You can't take a US calibration and use it in the FN2 - there are enough difference that they will not run the same. However, the FlashPro is programmable and someone with KPro tuning experience should be able to tune the ECU to the supercharger for you.
EFhatch
Post by EFhatch »
Hondata wrote:You can't take a US calibration and use it in the FN2 - there are enough difference that they will not run the same. However, the FlashPro is programmable and someone with KPro tuning experience should be able to tune the ECU to the supercharger for you.
I see ,thx! btw, i want to know what difference between Flaspro FN2 and FLashpro Civic SI since , from what i know , both use same wiring...
another question is, do USA dealer can suplly Non-US FlashPro? FN2/FD2?
No, you cannot get a non-US flashpro from a US dealer. They may have similar wiring, but the engines, and sensors are not all the same.
EFhatch
Post by EFhatch »
i see, so Civic SI ECU will not works with FN2 Type-R car, right?
