Kpro Serial Output problem
bjsinfield
Post by bjsinfield »
I have a K series ECU and don't seem to be able to configure the serial output option in the latest version.
I have the Dataloggingoutput=1 in the ini file but I cannot find the enable data logging option in the misc parameters the choices are normal, disabled and non-Honda.
I know i have had this enabled in a previous version but am wondering where it went unless non-Honda is the same as datalogging.
Thanks in advance
Brian
You will need to find the kmanager.ini file in the following location and make the change there. The ini file in the Kmanager directory in program files is no longer used. This is all because of Windows Vista virtualizataion.
Please read about this at http://www.hondata.com/help/kmanager/vi ... zation.htm
C:\Documents and Settings\*user*\Local Settings\Application Data\Hondata
bjsinfield
Thanks for the speedy answer, I read that but forgot about it.
