k20z3 into eg6
topekoms
k20z3 into eg6
Post by topekoms »
is there anyway to use the drive by wire for this swap?
im aware of the throttle body issue and using 02-04 ecu.
so now theres this new flashing thing. am i supposed to get the 02-04 ecu with change it to drive by cable stil? or is there new soliution for me cuz i have the stock ecu but i dont have key so the immobilizer wont work
Garrett_si
Post by Garrett_si »
the swap will be easier using RSX 05-06 wiring and RSX 05-06 Kpro + harness
Do not use the 05-06 KPro in an engine swap. Every KPro has an information sheet warning against this. See http://www.hondata.com/techk20transmissions.html
You will need to swap the transmissing case & throttle body. Also be aware that the K20Z3 engine has different mounting locations than the K20Z1 or K20A2.
Garrett_si
Hondata wrote:Do not use the 05-06 KPro in an engine swap. Every KPro has an information sheet warning against this. See http://www.hondata.com/techk20transmissions.html
5 of my friend did it :wink:
without VSS problem :twisted:
Perhaps that is why there are so many problems with engine swaps.
