Problem, very rich, bucking drivablity and very intermediate
d16z6_civic
Post by d16z6_civic »
Vehicle: 92 Honda Civic EX (EH9) D16Z6
ECU: USDM P28
MODS: Hondata 4 bar MAP sensor, S300 w/ boost control socketed by HONDATA
The problem exist very intermediate, this is the only graph I could get after about 20 times of trying and failing. Finally the problem is recorded, everything is very smooth before approximately 14:10. It becomes very rich (below 10:1 AFR RICH on PLX wideband) and bucks violently any throttle position above 0% (in the recording I maintain a steady throttle position according to my foot but yet % changes drastically). After a scary ride lasting to approximately to 14:32 everything is smooth as it should be. When this problem occurred in the past it may become extremely lean above 20:1 AFR. This problem recording is very short, in long term cases (that I do not have recorded) the AFR bounce from very rich to very lean in no change in the table position, being in OPEN LOOP (ignition and fuel map) Their was a few occasions it buck so violently until the engine stalled, after having extreme problems of idling. If I get a better recording, I'll update my post. Thank you for having this service and if you need any other information please do not hesitate to ask. d16z6_civic
d16z6_civic
Penny for your thoughts?
01101000011011110110111001100100011000010111010001100100
It is not in ASCII.
d16z6_civic
Hondata wrote:It is not in ASCII.
Gotcha, but about my problem, that would be greatly appreciated
Part of your problem is how you have the AF/voltage tables set up in the closedloop tab. You only have it set to read an AF of 0 to 10.8.
d16z6_civic
Spunkster wrote:Part of your problem is how you have the AF/voltage tables set up in the closedloop tab. You only have it set to read an AF of 0 to 10.8.
Note taken, thank you Spunkster.
At this time I have it in OPEN LOOP, my PLX is standalone and not communicating with the ECU.
FreshDA9
Post by FreshDA9 »
d16z6_civic wrote: At this time I have it in OPEN LOOP, my PLX is standalone and not communicating with the ECU.
Yep im having issues with my PLX aswell.
d16z6_civic
It is not a PLX issue, I choose to have it in OPEN LOOP and I choose have it not communicating with the ECU.
FreshDA9
Post by FreshDA9 »
o i seen no communicating and thought you were having an issue
d16z6_civic
Updated tune, problem caught red handed!! Problem 2 is more potent.
You may have some kind of wiring problem because you can see the battery voltage drop off, and while it does this you also see random spikes of the TPS and the map (to as much as 25psi).
d16z6_civic
Spunkster wrote:You may have some kind of wiring problem because you can see the battery voltage drop off, and while it does this you also see random spikes of the TPS and the map (to as much as 25psi).
Thank you, Spunkster
When the voltage is decreasing it is when my engine is running a very low RPM (323RPM) and the drop bellow 10.0v is when I was extensive cranking the engine, when the engine stalled because of the problem. I would expect that the voltage decreased. I have voltage dropped most of my engine harness wiring, and did not find any faults. If you have any more thoughts, it would be greatly appreciated.
d16z6_civic
Input would be greatly appreciated.
I would suggest taking it to one of our dealers to have them look at it and possibly tune it as well.
ITR 1102
Post by ITR 1102 »
I have had this same problem happen to me on two different occasions.
The ecu would throw a TPS code as well.
Somehow, my calibration was corrupt. I reverted back to an older backup copy that I had and everything went back to normal.
I could still open the calibration in Smanager and upload it to the ecu, but had very strange data logs and horrible drivability. Ever since this, I have kept mulitple copies of the calibration at various stages of the tuning.
