Reverse Lockout Gone with CT Stage 2 reflash
3point15SI
Post by 3point15SI »
I just wanted to make you guys aware that with the stage 2 reflash the reverse lockout for the transmission is inactivated. I was curious if that needs to be corrected or if it is just a byproduct that we will have to live with.
Doug is looking in to it now.
Hondata1
Reverse lockout fix
Post by Hondata1 »
We have replicated the problem are testing out the fix at the moment.
vtecmike1
Post by vtecmike1 »
hey hondata. is there anyway once this is fixed since i can't really afford downtime with my daily driver that i could drive down and just have the flash updated. i'm only 30 minutes from you guys and i don't have any time off left at my work for another 6 months. so i can't have my car not working for 3 days. plus it would save us both shipping expenses. anyway lemme know i know you don't normally do it that way but i was hoping you guys could help me out.
Mike
3point15SI
Thanks. I would like to know when it is fixed as well, just for peace of mind.
3point15SI
Also apparently the speedometer might be off and cruise control no longer works.
vtecmike1
Post by vtecmike1 »
my cruise control and speedo work just fine. however i have the gen 1 flash that has the reverse lock out disabled. i'm gonna stick with this flash.
in all honesty i never would have even known about it unless someone had told me so i went out and tested it. and sure enough a grind.
you'd have to be horrible or doing it on purpose to hit reverse while driving so since all of my other features work perfectly fine i'm gonna keep the gen 1 flash lol. at least till we have confirmation that all the issues are solved.
3point15SI
I know the people who are getting their reflashes now have the fixed versions...how about those of us with the 1st reflashes?
We are coming up with a solution for you and we will post it on our website when it is finalized.
