need help installing hondata boost solenoid on 04 rsx-s
afnewkirk13
Post by afnewkirk13 »
im not sure from where i need to hook up my boost solenoid lines. i know this isnt exactly where to post questions about this item but i didnt see anywhere else so im sorry. i know where to tap into the 12v source and into myy ecu but as far as the vaccuum lines im lost. any help is really appreciated and thanks for any help in advance
~KRUNK~
pb16b
Post by pb16b »
ignore the wiring, that's for s300. vacuum should be the same.
Suja 1 Motoring
1786 W Armitage Ct. Unit B
Addison, IL 60101
630-705-0818
http://www.suja1motoring.com
afnewkirk13
does it matter which side you hook the lines up to on the solenoid? thanks
~KRUNK~
If this is a Hondata boost control solenoid you will need to follow the instruction that came with the solenoid. If this is a GM solenoid then you need to follow the diagram posted above. If this is not a Hondata solenoid you will need to contact who ever you purchased it from.
