Which Dizzy?
teinxxx
Which Dizzy?
Post by teinxxx »
I have a D16Y8, I already have the P28 with the S300 on it and the conv. harness from OBD2 to OBD1 but i heard that i need a different distributor... Which distributor I need?
So much with a little D
As long as the distributor you have for that motor is OBD1 or OBD2 it will work.
teinxxx
Post by teinxxx »
so it doesnot matter if i am using a P28 with a S300 I dont need to swap my dizzy? I can still used the one that came with the D16Y8?
Spunkster wrote:As long as the distributor you have for that motor is OBD1 or OBD2 it will work.
teinxxx
Post by teinxxx »
Then I am Good to go with the Dizzy...
thanks
