B18B integra LS with Injectors Tacoma 2RZ
jucamaba2008
Post by jucamaba2008 »
I have installed a few Injectors of the tacoma 2001 2RZFE 2.4 L, # part oem Denso 23250-75080, spec 330 cc @ 43.5 psi (3bar) 13.9 ohms. How can I set the dead time voltage Injector compesation? Cracking set the fuel trim? Throttle tip in trim?
You would have to have to either get the specs from the manufacturer of the injector or have some aftermarket injector company test them for you and give you the specs. It is not something we have or can test.
