grounded starter wire, solid cel, fried ecu/hondata? how ca
.adam.
Post by .adam. »
well on the initial start up on my car, my friend went to tighten down the starter wire and grounded it on the body of the starter. not knowing this, it stayed grounded for a few minutes and ruined my battery. after replacing the battery and trying to start the car, i got it to run, but with a solid cel. it ran like it was in limp mode and would not rev high. my ecu is chipped with hondata s300 and it connected, but would not datalog and the little light by the usb plug is a constant red. is there anyway i can find out what is bad with an ohm/volt meter and try to fix/replace it. all fuses are still good. im working on getting another ecu with s300 but cant really find anything yet. :oops: :oops:
.adam.
Post by .adam. »
also,
this was a known working s300 ecu from last year, and i can upload maps, but cant datalog. the light right by the plug is red, but the other farther in is green.
What version of software are you using?
.adam.
Post by .adam. »
1.4.0.0
Please download the newest version of software, then create a new calibration by going to File, New and upload that to the ECU.
.adam.
Post by .adam. »
do you think that that could fix the problem? sorry about all the questions, its just that at my garage i dont have wifi so im trying to do as much as possible to be able to fix it before i go back. anything else you along with that you might suggest before i go at it again?
thanks for all the help and quick responses btw!
That is the first thing you need to try.
.adam.
Post by .adam. »
it worked!!!! thanks for the suggestion. you have no idea how much i appreciate it! :D :D :D :D :D :D :D :D
boosted93coupe
Post by boosted93coupe »
i have the same problem and i tried reuploading my old map and it just comes up with an error? have any ideas?
