Idle hunting Kpro Rotrex SC install
luke_sedz
Post by luke_sedz »
Hi,
I have recently fitted a rotrex supercharger setup to a UK EP3 K20A. I had this SCto a different car so still have the same map. The setup now has a FMIC instead of top.
I installed the setup and had it running last week but i had a problem with some of my piping to the supercharger flexing to much. I have now changed it all to solid pipe, started the car up and it has a hunting idle.
When i start the car the RPM gradually climbs to 2500RPM and then drops back to 1000RPM and bounces between 1000RPM and 2000RPM.
I have uploaded my data log of it running for a few seconds to see if it shows anything.
Anyway i hope someone can help clear the problem up.
Thanks a lot
Luke
Looks like a vacuum leak of some kind. You'll need to find the source of the leak and fix it.
cranny
Post by cranny »
a substantial vacuum leak id say by the map readings. should be -20 fully warm at idle approx.
Boofster
Post by Boofster »
That's funny I have this same issue on my S2k Rotrex.
Is -20 vac standard for all cars?
Da Boost
