Wideband switched power source
bsclywilly
Post by bsclywilly »
Where should I pull the power for the O2 heater? Is it okay to draw load from the ECU power/ground (A25/A26)?
Vehicle is a 93 Civic with JRSC and 550cc injectors.
No, do not ever get power or ground from the ECU.
You should use the extra spaces provided in the fuse box for power and use a good solid chassis ground.
