DTC 1607 What now?
bjsinfield
DTC 1607 What now?
Post by bjsinfield »
I have ECU error 0 DTC 1607, what can I do now short of buying a new ECU.
Tried reloading a stock map and clearing code a number of times, but no luck the error appears to be permanent. Tried another ECU no error code.
Is there anyone who repairs these or do I bite the bullet buy a stock ECU and pay for another upgrade to Kpro?
Brian
What is the code on the side of the ECU? What is the code on the inside of the ECU on the white connector? What type of calibration are you loading (PRB, PRA, PND, PNF)?
Please post your calibration.
bjsinfield
Outside code 37820-PRB-A05
2068-500342 0J03 inside the same
Hondata serial number 0029
Application K20A turbo in ex-IMSA GTU Dodge, 12 psi boost
Kal file attached.
Serial logging was turned off in this version of the KAL
Brian
Unfortunately it cannot be repaired. If you have tried clearing security and uploaded a fresh calibration from File, New and the error is still there then the ECU is damaged and will need to be replaced.
