Vtec upper/lower boundary K20A3?
k20mini
Post by k20mini »
It seems that all of the standard maps in the kpro have the upper and lower vtec boundaries set at 2200 rpm's.
Should both be set at the same RPM's?
Thanks.
Which calibration are you referring to?
Different calibrations have different settings. Go to File, New.
k20mini
Post by k20mini »
I used the one for a k20A3 92 octane.
Is this not correct?
IF you have a pretty much stock k20a3 then that is the stock setting for VTEC.
k20mini
Post by k20mini »
10-4.
I am pretty stock. I just didnt think that the upper and lower boundaries was supposed to be set that way.
thanks
Bflaker
Post by Bflaker »
Wait, so you have a K20a3 in your mini, not a K20a2?
*OFF TOPIC* Where are you located? That mini looks freakin' awesome!!
03' RSX Type-S
I/H/E/RBC/K-PRO/100shot/555R's
13.2 @ 109mph w/ 2.0 60'
k20mini
Post by k20mini »
Yes. K20A3.
Near Houston.
Thanks,
