Dataloging problem......
Turbo ex
Post by Turbo ex »
Im currently running s300 in my race car and i have the logger to come on at 4000 rpm and 50% throttle but when i do a burn out or make a pass i get nothing the car does have a m&w ignition box and its mounted as far away from the ecu as possible and im using resistor type plugs do i need to try it on a switch the car is a full race car and does not see street driving what so ever.
Make sure all parameters are being met. Post your calibration and a datalog made with a laptop showing the problem.
Turbo ex
Post by Turbo ex »
Ok call me crazy but i cant post a datalog as i can not get it to record. Thats the problem as far as posting my parameters you me like my datalog parameters? Not my tune right ?
fly_n
Post by fly_n »
the datalog parameters & "tune" are all in the one "calibration" file,post that up.
will it still not even record if u set datalog parameters to "use manual switch">>>>>>"always on"?
i had a random problem a few weeks ago,where my laptop decided to not see any of the onboard recordings. By the time i checked it again a few hours later,all the recordings came up,in other words check your laptop is connecting properly as well.
Do not use on-board datalogging, turn it off. Use a laptop to record and post the files.
turbotypeR
Post by turbotypeR »
Just use a switch to manually turn on the datalog. That is what I did and I have never had a problem with it.
92 civic Si
best et:9.43best mph:164
