2 step will not stop
itr909
Post by itr909 »
Hello, I have just been tuned and the tune went great. I drove home and everything was cool until I tested the 2 step! After the tune the tuner and I set the 2 step at 3800 rpms and worked perfectly. Now I can't revs over 3800 rpms in any gear. i have checked the VSS and that is getting a reading however I was also told to check the clutch switch, how do I check the clutch switch on the S300. I am willing to remove the 2 step all together, I just did not know how. Sorry if this has been covered. I just need some help guys, thanks.
fly_n
Post by fly_n »
for clutch switch,
check which input is being used under the launch control tab in parameters.
then just datalog the input & make sure its going on & off when u work the clutch pedal
what is max speed set at in launch control tab? & try inverting the input.
itr909
Post by itr909 »
Sorry i didn't post the info on my ride, my bad I'm a newbe LOL.
:oops: MY set up
1) GSR MOTOR and LS tranny in EG SI
2) Full Race Pro Am Top mount manifold
3) t4 Turbonetics turbo
4) Spearco IC
5) 2.5 piping
6) 3 inch down pipe and 3 inch straight back without cat, muffler Vibrate 3 inch
7) Greddy RS BOV
8) Victor X intake manifold
9) RC 550 injectors
10) AEM fuel rail and fuel regulator
11) Hondata S300 (p28) obd1
12) NGK spark plugs
13) MSD 6al, external coil ss, new cap and rotor
14) Fuildene raditor
15) 12 inch slim fan
16) New timing belt, water pumper and type R oil pump
17) Morsoso oil pan tapped for turbo oil line, oil line sandwich adapter for oil return line
18) Greddy turbo timer (not necessary)
19) greddy Profec boost controller
20) DC short shifter
21) Clutch MAster stage 3 clutch and fly wheel
22) Hasport mount all 3
23) Walbro 255 fuel pump
24) 2 layered screen filter for turbo
25) Tial 44m wastegate
26) Prosport gauges (Boost, Water temp, Oil temp)
27) AEM map 30 psi
