High voltage reading from o2 sensor
crxb18c1
Post by crxb18c1 »
I replaced my o2 sensor with a new denso sensor after finding a abnormal high reading from the o2 sensor. The problem seemed to be fixed then a few days later i looked at the o2 readings and i was reading high voltages (3.0-3.8). Any insight would be much appreciated.
b18c1 obd1 conversion with rywire harness.
GTMcoupe
Post by GTMcoupe »
loose connection within the harness, or prehaps the pin in the plug has pushed out,
West
Its Small, Its Red, Its Mid engined, It has a B18 fitted, 250hp+per tonne + nitrous
crxb18c1
Post by crxb18c1 »
Im going to check the connections at school this evening. Does anyone else have any ideas what would make a newly replaced o2 sensor ready 3.87 or so at idle.
that or excessive vibration.
