Launch Control switch
aspecha
Post by aspecha »
noob question but:
I wanted to wire in a normal switch to turn launch control on and off. Same type of switch that you would use to turn on/off a LED. What one of the selections on the Kmanager E16, E29, E22, or B9. What one of those could i tap into to run the switch? And do i tap into the ECU wire or could i do it from somewhere else like by one of the pedals or whatever those options are to engage it instead of using always on.
Thanks for your help!
You can use any of the inputs listed in the software. It is completely up to you which one you use. You must use this in conjunction with the clutch switch for it to operate correctly though.
aspecha
Post by aspecha »
the wiring is my only question. I start with my switch. It has two wires on it. I run one to the input of my choice and the other to the clutch switch?
If you already have a clutch switch you don't need another switch. If the input you use is a grounded input then on wire form the switch goes to the ecu input and the other goeas to ground.
